Unintuitive Wald Test Results
Dave_the_Forecaster
Postby Dave_the_Forecaster » Fri Oct 04, 2013 6:32 am
I have estimated an equation with the following results:
Variable | Coefficient | Std. Error | t-Statistic | Prob.
C(1) | 0.125698 | 0.157044 | 0.800397 | 0.423700
C(2) | 0.765549 | 0.851063 | 0.899522 | 0.368700
C(3) |-0.163058 | 0.320517 |-0.508735 | 0.611100
C(4) |-0.003991 | 0.106239 |-0.037570 | 0.970000
C(5) |-0.464766 | 0.245652 |-1.891971 | 0.058900
C(6) | 8.757433 | 10.08753 | 0.868144 | 0.385600
To me, this means that all of the variables are effectively zero except for variable 5.
I want to test the hyposthesis that all of the variables are zero.
So, when I perform a Wald test with the restriction c(1)=c(2)=c(3)=c(4)=c(5)=c(6)=0, I get a p-value from the F-test of 0.064 (as expected)
However, if I exclude variable 5 from the Wald test restriction (ie. test the statment c(1)=c(2)=c(3)=c(4)=c(6)=0) I get a p-value of 0.05
Basically, by excluding each variable in turn I discovered that it is variable 4 (the variable which seems closest to zero in the estimation) which is causing the rejection of the null-hypothesis in the Wald test.
Can somebody with better stats knowledge than me explain why this is happening?
Re: Unintuitive Wald Test Results
Postby startz » Fri Oct 04, 2013 8:18 am
You probably have substantial multicollinearity. The regression knows that the variables collectively matter, but can't separately tell which one(s) are really nonzero.
Dave_the_Forecaster
Postby Dave_the_Forecaster » Fri Oct 04, 2013 9:03 am
Thanks for replying.
So I shouldn't be drawing any conclusions from the individual t-statistics, rather, I should only trust the 'collective' results of the Wald test?
Postby startz » Fri Oct 04, 2013 9:09 am
That's probably right. At least if the variables you have are all measures related to some common phenomenon.
Postby EViews Gareth » Fri Oct 04, 2013 9:40 am
One of those cases where "Non-normality and collinearity are problems!"
