is it possible to do Wald test in Bayesian VAR (the option under View-Lag structure says it is unavailable) manually?
Wald test in Bayesian VAR?
Re: Wald test in Bayesian VAR?
It is not built in. (I'm not sure of the validity of Wald tests under a Bayesian VAR anyway...)
Maybe it is not the best thing. Sure I would appreciate for instance Bayes factors (see http://en.wikipedia.org/wiki/Bayes_factor) but I assume you do not plan to implement this either.
So, is there a way to do the Wald test manually? I.e. is there a covariance matrix available?
