Solving for the addin factors for a group of trajectories
renjinlu
Postby renjinlu » Tue May 26, 2009 7:46 am
Hi, I have a question regarding add-in factors.
Using the Macromod workfile in our Eviews manual as an example. Suppose I give the model (with three equations for CN, R, I and one identity) a name "lalatest", and in baseline scenario, I solved for the static solution
lalatest.scenario "baseline"
smpl 1960q1 1999q4
lalatest.solve(d=s, o=g)
And then I created a comparison scenario with a dynamic solution
lalatest.scenario(n) "comparison1"
lalatest.solve(d=d,o=g)
Obviously, the dynamic and static solutions are different, and I want to use the addin factors to make the "comparison 1" scenario dynamic solution the same as the baseline. Here is what I did:
lalatest.addassign(v) @all 'create addin factors
lalatest.control cn_a cn cn_0 'Solve for the addin factor for CN
lalatest.control i_a i i_0 'Solve for the addin factor of I
lalatest.control r_a r r_0 'Solve for the add in factor for r
lalatest.control y_a y y_0 'Solve for the add in factor for y
Unfortunately, it does not work. How can I make the solution of a model, with interactive equations in the model, equal to a set of trajectories? Thank you for your help!
EViews Chris
Re: Solving for the addin factors for a group of trajectories
Postby EViews Chris » Tue May 26, 2009 12:04 pm
I think the following approach will do what you asked for, although I'm not entirely sure what you're trying to achieve.
Try out the code below and see what you think.
lalatest.scenario "baseline" smpl 1960q1 1999q4 lalatest.solve(d=s, o=g) 'create a comparison scenario with a dynamic solution lalatest.scenario(n) "comparison1" lalatest.solve(d=d,o=g) 'obviously, the dynamic and static solutions are different, and I want to use the addin factors to make the "comparison 1" scenario dynamic solution the same as the baseline lalatest.addassign(v) @all 'create addin factors 'back up actuals copy cn cnb copy i ib copy r rb copy y yb 'overwrite actuals with scenario 1 cn = cn_0 i = i_0 r = r_0 y = y_0 'solve for add factors lalatest.addinit(v=n) @stochastic 'restore actuals cn = cnb i = ib r = rb y = yb 'solve with add factors lalatest.solve(d=d,o=g) 'show results: cn_2 should equal cn_0 show cn cn_0 cn_a cn_2
renjinlu
Postby renjinlu » Tue May 26, 2009 1:17 pm
Cool! It worked perfectly. You saved me a lot of time. Thanks!
Return to “Models”
