'and' syntax error erased data entry
stefan
Postby stefan » Tue May 26, 2009 3:21 am
Hope this is the right directory:
I've made a dummy "workfile data item" (not sure of the right name, it is a file of a variable) of two data items, by the
command: group acq_target @expand(acquirer, target)
This gives me a item with three colloms: ACQUIRER=0 AND TARGET=1 ; ACQUIRER=1 AND TARGET=0 ; ACQUIRER=1 AND TARGET=1
I drop the last one, to avoid the dummy trap, by making a new file command:
group acquirer1_dropboth @expand(acquirer, target, @droplast)
This creates the (G) file entry I need, and can use without problems. however when I open the eviews file the next day, It gives the error
message: syntax errorr in "and"
and the colloms in the file are erased WHY??
the data entry item then only has one collum left, which now states ACQUIRER=0 ; the rest has disappeared
I am using eviews 6, however at university so on different computers.
(it does the same truble but worse when also using eviews 5 interchangeable)
But then it erases entries in even more created (dummy) data items.
Re: 'and' syntax error erased data entry
Postby EViews Gareth » Tue May 26, 2009 8:06 am
Looks like a bug. We'll look into it.
stefan
Postby stefan » Tue Jun 16, 2009 9:01 am
Any new thoughts on the problem?
It keeps erasing worksfile entries with and in it.
Postby EViews Gareth » Tue Jun 16, 2009 9:16 am
We have a fix, just waiting on the patch to be fully tested. Hopefully in the next couple of days.
Postby EViews Gareth » Tue Jun 16, 2009 12:18 pm
stefan
Postby stefan » Wed Jun 17, 2009 6:50 am
Thank you very much !
stefan
Postby stefan » Wed Jun 17, 2009 7:08 am
After clicking run, Eviews gives the following error message:
error installing ikernel.exe: (0xa00)
What does it mean is it that I don't have enough rights (and need to send it to the administrator) or is it a different issue.
Thank you again for the patch
Postby EViews Gareth » Wed Jun 17, 2009 8:02 am
Yep, that means you don't have enough rights.
stefan
Postby stefan » Tue Jul 07, 2009 5:19 am
I send it to the administrators office.
Is it possible to see somewere if the patch has been installed ?
(without having to do the work and finding out the next day that it all has disappeared again..)
Postby EViews Gareth » Tue Jul 07, 2009 6:53 am
Check the build date of your copy (click on Help->About EViews)
