ARMA fitting and forecast
ghostwriter
Postby ghostwriter » Mon Sep 02, 2013 2:38 am
Hi all,
To begin, I have limited knowledge in programming but I need to somehow generate a program that can enable me to find the best ARMA model (minimize AIC) starting from ARMA 0,0 to ARMA 5,5 on a rolling basis (over 4000 data points). After the best model has been selected I would like the program to perform a 1 step ahead forecast. Ideally, I would like be able to view the model selected at each point and the forecast generated.
Could you point me in the right direction?
Thank you in advance.
ghostwriter
Re: ARMA fitting and forecast
Postby ghostwriter » Tue Sep 03, 2013 11:46 pm
Good day,
I have managed to successfully run the following program on my data. This has enabled me to find the best model (minimize AIC) for the entire period. How can I modify this program to help me do the same on a rolling basis i.e. every 500 observations and store the best model at each point?
%eqname = "EQ01" 'name of equation object that will be used.
%maxAR = "5" 'maximum number of AR terms
%maxMA = "5" 'maximum number of MA terms
%dep = "SPX" 'dependent variable
%regs = "C " 'independent variables
%criterion = "@AIC" 'which criterion to use enter "@AIC" for Akaike, "@schwarz" for Schwarz, and @HQ for Hannan-Quinn
!maxAR = @val(%maxAR)
!maxMA = @val(%maxMA)
close {%eqname}
'create table for storing critical values.
%matname = "crits"
if @isobject(%matname) then
%matname = "__crits"
delete {%matname}
endif
endif
table(!maxar+2,!maxma+2) {%matname}
{%matname}(1,1) = "AR / MA"
{%matname}.setlines(1) +b
{%matname}.setlines(a) +r
'set sample
smpl @first+!maxAR @last
!mincrit = 1e12 'set the minimum to an artificially large value to begin
'estimate the models
%arstring = ""
for !i=0 to !maxar
'build up string for AR terms.
if !i>0 then
%arstring = %arstring + " ar(" + @str(!i) + ")"
endif
%mastring = ""
for !j=0 to !maxma
'build up string for MA terms
if !j>0 then
%mastring = %mastring + " ma(" + @str(!j) + ")"
endif
'estimate equation
equation {%eqname}.ls {%dep} {%regs} {%arstring} {%mastring}
'capture criterion
if @upper(%criterion) = "@AIC" then
!crit = {%eqname}.@aic
endif
if @upper(%criterion) = "@SCHWARZ" then
!crit = {%eqname}.@schwarz
endif
if @upper(%criterion) = "@HQ" then
!crit = {%eqname}.@hq
endif
'compare criterion
if !crit < !mincrit then
!mincrit = !crit
!bestAR = !i
!bestMA = !j
%bestARstr = %arstring 'store the best ar string
%bestMAstr = %mastring 'store the best ma string
{%matname}.settextcolor(@all) black 'table formatting.
!ii=!i+2
!jj=!j+2
{%matname}.settextcolor(!ii,!jj) red
endif
{%matname}(!i+2,!j+2) = !crit
{%matname}(!i+2,1) = !i
{%matname}(1,!j+2) = !j
equation {%eqname}.ls {%dep} {%regs} {%bestARstr} {%bestMAstr}
show {%eqname}
show {%matname}
regards,
Ghostwriter.
