Aggregation of Panel Data
corona
Postby corona » Tue Aug 27, 2013 1:26 pm
I have an unbalanced panel which consists of: 1) hundreds of unique individual id; 2) a group id (A,B,C); 3) T time periods; 4) other variables
I want to create a panel in which the individuals are aggregated by group, so that the panel is 3xT.
I have created a new page using group id as the cross id, then performed a matched merge, contracting using the mean. I must be doing something wrong because the values of the other variables (weight, height, etc.) are the same across groups for corresponding time periods. Is there a step-by-step example of how to correctly do what seems like should be a common application?
Re: Aggregation of Panel Data
Postby EViews Gareth » Tue Aug 27, 2013 1:27 pm
Could you provide your workfile (or an example of similar structure)?
corona
Postby corona » Tue Aug 27, 2013 2:29 pm
Attached is a workfile. I want to aggregate dq by proptype and activitydt. Then in another page I want to aggregate dq by purposetype and activitydt. BTW I am using EVIEWS 8 Enterprise 64 bit.
test v3.WF1
(1.15 MiB) Downloaded 220 times
Postby EViews Gareth » Tue Aug 27, 2013 4:03 pm
These are the steps I took, which seemed to work:
http://www.eviews.com/Forum_support/Pan ... llapse.htm
corona
Postby corona » Wed Aug 28, 2013 2:02 pm
Thank you that does the trick!
