I am using Eviews 8. My question related to census X12. I have a program that starts with Westpac.x12(mode=a,save="d12"), where Westpac is a series, I am keeping getting this error msg:
"You cannot run Census X-11/X-12 from a shared directory which has spaces in its name in "DO_WESTPAC.X12 (MODE=A,SAVE="D12")"
I check the variable Westpac and there is no space in the name.
Can you help me out?
Census X12 programming
Re: Census X12 programming
The problem is the location of the EViews installation. X12 cannot be installed on a shared drive with spaces in its name.
Thank you.
So how I fix it? I have to change the name where the Eviews 8 is located to Eviews8, for instance.
Yes, you'll have to re-install EViews to another location.
It works, thank you very much
