Rolling VaR estimates
Re: Rolling VaR estimates
Suppose you have a return series called rt. Then, for EWMA you can try:
And as for GJR with t-distribution:
Finally, to obtain the lower %1 quantile of a series y:
Please note that, all these commands (and many more) are available in the users guide.
!alpha = 0.02 'you should provide an appropriate value for this parameter
smooth(s,!alpha) rt^2 ewmaCode: Select all
arch(1,1,thrsh=1,tdist) rt cCode: Select all
scalar q1 = @quantile(y,0.01)Re: Rolling VaR estimates
I run the programs, but it keeps showing up error messages. And have tried to adpat the codes, but couldnt figure out what the problem is!!
Could someone please help, by perhaps even giving some hints at the problems? I very much appreciate your time!
Thanks.
Thanks.
%smpl = @str(!i) + " 1250"
scalar x = @elem(ewma, %smpl)
Gareth,
When i run it, it shows up 'Illegal date 1 1250 in “scalar x = @elem(ewma, "1 1250")"
What could be the problem here?
Sorry, I posted without thinking.
I don't understand what you're trying to do with that line. @elem takes a single date, not a range of dates.
scalar x = @elem(ewma, "1251")
I tried to modify your code so as to perform what you want and to give you the idea for further adjustments. However, I suggest you to go over An Introduction to Eviews Programming before moving forward.
!window = 1250
!length = @obsrange
!alpha = 1-0.94 '1-alpha is the coefficient of estimated variance
!scale = 10000 'it might be a good idea to adjust the scale
series x 'create the output series beforehand
matrix(!window,!length) results 'you can create a matrix to store all the resulting smoothed series
' move sample !step obs at a time
for !i = 1 to !length-!window
smpl @first+!i-1 @first+!i+!window-2
smooth(s,!alpha) !scale*returns^2 ewma
stom(ewma,ewmat) 'convert series to a vector
colplace(results,ewmat,!i) 'place the vector into the matrix
x(!window+!i) = ewma(!window+!i)
smpl @allWho is online
