1. About Tramo: I get slightly different results when I use the windows version of the Tramo module from the website of the Bank of Spain, and the Eviews built-in version of Tramo. I use the most recent Tramo/Seats Windows version available from the website of the Bank of Spain which is named Beta 1.0.4 rev.136 (March 2009) (see http://www.bde.es/servicio/software/econome.htm). The manual included with Eviews 6 hints that a rather old version is used, because it states Beta Version: November 1997. So I would like to know which version of Tramo/Seats is used in Eviews 6, and whether it is possible to manually update the built-in Tramo/Seats version.
2. About X-12: Here, I also get slightly different results when I use the windows interface to X-12 ARIMA, and the Eviews build-in version of Census X-12. Eviews tells us that X-12 version 0.2.9 is being used. However, only more recent versions are available from the website (see http://www.census.gov/srd/www/x12a/x12down_pc.html). So quite similar: Is it possible to adjust Eviews 6 in such a way that it uses a manually updated version of X-12?
Tramo/Seats and X-12 versions
Re: Tramo/Seats and X-12 versions
Both X12 and Tramo/Seats are using old versions, and no, it is not possible to update them.
alejandro123147
hello. I'm alexis and I have bit question.
I have been using the tramo/seats on a series, but when I apply it, the series "_SA" is same to "NA", in all the series.
Why ? I don't understand it
