Hypothesis testing
monica88
Hypothesis testing
Postby monica88 » Wed Jul 10, 2013 1:57 am
I have done OLS estimation with panel data (in a panel workfile) and would like to do some hypothesis testing (I am using EViews 7).
A) I need the t-ratio for the hypothesis that the difference between two coefficients is zero (against the hypothesis that the two coefficients differ). Do I use the Wald test for this? If the two coefficients are C2 and C4 would I just write in the box "C(2)=C(4)"?
B) I need to also test the hypothesis that one coefficient exceeds the other. How would I do this?
Thank you for your help!
Re: Hypothesis testing
Postby EViews Glenn » Wed Jul 10, 2013 10:22 am
monica88
Postby monica88 » Thu Jul 11, 2013 2:39 am
Thank you very much, you are very helpful!
This might be a stupid question, but do I use the same degrees of freedom as reported for the two-tailed test (wald test) when I look up the critical value in the table for the one-tailed test?
I really appreciate your quick answers :)
Postby EViews Glenn » Thu Jul 11, 2013 9:33 am
Yes. It's the same statistic, you're just looking at one-tail of the distribution. Note that given symmetry, the p-value should be half of the quoted p-value.
