Importing tick-by-tick data in Eviews 7
Hello!
I am trying to import a file that has tick-by-tick data for 5 years of EUR/USD prices. The original file is csv, with "YYYY-MM-DD HH:MM:SS, bid, ask".
My problem is that I cannot explain to eviews the date format...
If I say "dated - specified by date series", frequency autodetect or intraday, I get "Indicies do not uniquely identify observations. 1458177 duplicate date(s) found. Create CELLID series to identify observations?"
I assume it says "duplicate dates" because there are several seconds within the same day, so I was wondering how I could overcome this problem?
Sample of the date column:
2002-12-01 19:27:18
2002-12-01 19:34:46
2002-12-01 19:38:36
2002-12-01 19:46:17
2002-12-01 19:46:27
2002-12-01 19:56:11
2002-12-01 20:18:06
2002-12-01 20:18:43
2002-12-01 20:18:59
2002-12-01 20:19:39
2002-12-01 20:31:35
2002-12-01 20:37:48
The file is almost 500MB so I cannot attach it... Any ideas? please..
Thank you very much
Eviews 7
2002-12-01 19:27:18
2002-12-01 19:34:46
2002-12-01 19:38:36
2002-12-01 19:46:17
2002-12-01 19:46:27
2002-12-01 19:56:11
2002-12-01 20:18:06
2002-12-01 20:18:43
2002-12-01 20:18:59
2002-12-01 20:19:39
2002-12-01 20:31:35
2002-12-01 20:37:48
Thank you very much
Eviews 7
Re: Importing tick-by-tick data in Eviews 7
What I need in this series is just a few days here and there. Would it be possible to create a blank series of 2 days (say 2003-01-15 and 2003-01-16) with frequency 1 minute (for example) then fill the series with information I got from the original series?
I'm very sorry if it's getting complicated...
If you have multiple observations with exactly the same time-stamp, you cannot structure your workfile as a dated workfile.
Gareth,
Thank you for your reply. This was embarrassingly obvious. I shortened the set to 500 observations and the dating happened fine...
I didn't think duplicates would occur in this set though.. May I just ask if there is a command to search and add a second to any duplicates in the dates? They are ordered in increasing order if that helps.. (I know I shouldn't change the data like this but I will not use it at second frequency but rather 5 minutes or even lower)
Thank you very much!
Unfortunately there is no such command (nor can I think of an easy way to do it programmatically).
Ok, thank you very much!
Maybe some variant on
seconds = @recode(seconds=seconds(-1),seconds+1,seconds)Re: Importing tick-by-tick data in Eviews 7
Yes, exactly like that! I have been looking around and changed it toMaybe some variant on
??Code: Select all
date2 = @recode(date=date(-1), @dateadd(date, 1, "ss"), date)Hence it could have worked, but of course it does not here... I think I should simply delete the points but I have to do it for each series, i.e. if in series date entries 1000 and 1001 are the same (say 2002-12-12 12:12:00), then I should delete entry 1001 in date, series01, and series02.
Is it possible to do that?
(I still know it is butchery of data but I don't have much choice...)
EViews dates have a resolution of a millisecond, so there may be a way to do what you want by adding a small enough fraction that you don't bump up to the next observation.
That's a good idea, I have tried it and it indeed works. My last problem is that I have to repeat the step a certain amount of times until eviews tells me there are no more duplicates and I don't know how many times that is (it appears it is possible that more than two points may have the same date).
I will search the manual for how to do a loop or a different way of doing this. Thank you very much
You may need to be careful about the following. Suppose three dates in a row are identical. The program will change the second one. Observations 1 and 3 will still be the same but that won't be caught.
Perhaps a more pertinent question would be - do you actually need this data to be in a dated workfile?
What Gareth said.Perhaps a more pertinent question would be - do you actually need this data to be in a dated workfile?
But if you do need a dated workfile you might want to compare s to s(1) rather than s(-1). I think this should make the changes in one pass.
Yes I was thinking about the 3 dates in a row or even more, I'll have to think about how to handle that! If I get a straight forward script I'll post it in case someone has the same problem.
And yes I do need the data dated. Sometimes I wish I could find another way but I do need it dated. But thank you for your concern
