TVAR (Threshold VAR)
Scalper
Re: TVAR (Threshold VAR)
Postby Scalper » Fri Nov 11, 2011 2:51 pm
Will be the threshold value that share each regime??
gordeza
Postby gordeza » Sat Nov 19, 2011 1:42 am
Hi Gareth,
Thanks a ot for helping thousands in this forum.
It would be greatly appreciated if you could elaborate a bit more on how to get the threshold value display in the TVAR output.
Also, how to edit the add-in code?
Thanks in advance.
Gordeza
Postby EViews Gareth » Sat Nov 19, 2011 3:08 am
The R program doesn't return the threshold value, so it can't be brought into EViews.
To edit any Add-in, simply open up the file in EViews. (File->Open->Program in Addins folder)
agranda
Postby agranda » Thu Dec 29, 2011 8:09 am
I get the very same error message that Mihaain and Gordeza mentioned early:
"R(for 'testtar<-TVAR(g, 3, include="const"model="TAR",thhresh=1)') returned an error: evaluation stopped because of an error".
Any idea? I don't find the error
(add my wf1)
Thanks in advance!
exam_model.WF1
(20.2 KiB) Downloaded 1168 times
Postby EViews Gareth » Thu Dec 29, 2011 8:51 am
What was the specification you used?
agranda
Postby agranda » Thu Dec 29, 2011 9:04 am
the specification is
TVAR(options) 3 ipc_ln tc_v
Postby EViews Gareth » Thu Dec 29, 2011 9:57 am
Looks like it is just an issue with the R package for your particular data set.
yasirjanjua
Postby yasirjanjua » Wed Aug 08, 2012 2:51 am
Hello dear fellows, i have installed the R with rsc proxy and couldnot find the statconnDCOM version 3.1-1B2 if someone have plz attach as soon as possible.
yasirjanjua
Postby yasirjanjua » Fri Aug 10, 2012 4:58 pm
Dear Fellows
i have run the program properly but having estimation error in the following command
> test<-TVAR(G, 2) which is not working properly
how can i resolve it
plz reply soon
thanks
Potti_X
Postby Potti_X » Mon Aug 20, 2012 9:55 am
is there any way to use this addin for forecasting?
Postby EViews Gareth » Mon Aug 20, 2012 11:16 am
Not as far as I am aware.
afham_acc
Postby afham_acc » Thu Sep 13, 2012 1:32 am
I have a problem that says "R(for 'test<-TVAR(g, 1, include="const"model="TAR",nthresh=1)') returned an error: evaluation stopped because of an error" And I tested with the testtvar.wf1 gordeza has sent and it worked perfectly...So, i figured this must be a problem with my dataset...could u please help me with this?
I wanted to test the TVAR between g-inf and g-exrate...with lagged 1 and delay parameter 1...
is it because my sample size is too small?
thesis.wf1
(9.61 KiB) Downloaded 1071 times
valeria
Postby valeria » Fri Jun 21, 2013 6:30 am
Hello! I'm trying to estimate a TVAR with 3 endogenous variables and 2 lags. I chose the threshold variable, as a function of one of the variables of the model with 1 delay and I can make an assumption about the threshold value, setting it to 0 (as it is in the literature). Using the TVAR Add-in I'm able to activate the R-connection properly, but when I estimate the model the output displays all coefficients equal to 0. Can I specify somewhere in the estimation screen the threshold variable?
I would really appreciate help.
Thank you!
Valeria
Postby EViews Gareth » Fri Jun 21, 2013 7:43 am
No, I believe not.
valeria
Postby valeria » Fri Jun 21, 2013 8:39 am
So what is the meaning of this result?Am I doing something wrong?
Return to “Add-in Support”
Users browsing this forum: No registered users and 3 guests
