hi, I am working on a dynamic factor model. I try to use the state-space model to figure out a common factor for GDP of different countries.
The model I use is:
Y(t) = A*Y(t-1) +B*F(t) +u(t)
F(t) = C*F(t-1) + e(t)
The F(t) is the dynamic factor model(unobservable), I enter the following code in the eviews 7:
@signal uk = c(11)*sv1 + c(21)*uk(-1) + [var=exp(c(1))]
@signal germany = c(12)*sv1 +c(22)*germany(-1) + [var=exp(c(2))]
@signal france = c(13)*sv1 +c(23)*france(-1) + [var=exp(c(3))]
@state sv1 = c(31) * sv1(-1) + [var=exp(c(32))]
But the standard error, z statistics and probability are all "NA". What's wrong with the code? Could anyone help?
Thank you!
state-space model
Re: state-space model
Nothing appears to be wrong with the code. You might tryhi, I am working on a dynamic factor model. I try to use the state-space model to figure out a common factor for GDP of different countries.
The model I use is:
Thank you!
(1) Changing the model some. Perhaps constants in each equation?
(2) Try different starting values for the parameters?
