First, in the manual book, the series views should be "bdstest(options)" instead of "bds(options)".
Second, is there any way to save the bootstrapped p value?
Third, how to hide the test result window? For example, I use a loop to do the test for N series and would not like the N windows to pup up.
Thank you!
bds test
Re: bds test
Thanks for the correction.
Put a "do" in front of the command to stop the window from popping up:
For retrieving the p-values, you'll have to freeze the output into a table.
do myseries.bdstest
Re: bds test
Thanks, but is there any way to save the bootstrapped p value?
Re: bds test
Only the method I mentioned
Re: bds test
