No prompt to save programs on close
EViews requires users to chose if an altered workfile should be save when they close it. But when closing altered programs this prompt does not appear.
Re: No prompt to save programs on close
There was an issue of EViews not prompting to save programs under certain conditions that was fixed in the last patch. What build of EViews are you using (Help->About EViews)?
If you are not using the May 17th build, select Help->EViews Update to get the latest version.
If the problem persists, please describe the steps whereby EViews is not prompting.
I updated and now it works just fine. My bad
