How to update a high frequency dataset using a timestamp var
neophytosk
Postby neophytosk » Thu May 23, 2013 6:53 am
Title: How to update an unstructured high frequency dataset using a timestamp variable
Dear all,
I have the following question.
Background
I have a timeseries dataset regarding fx trades with different counterparties as below, location of exchange etc (which are not included in the example). Key variables are the categorical variable 'counterparty type' indicating which is the originating side of a trade (who is trading), and some numerical variables as the exchange rate(price) by which the transaction is settled. The 'time' variable is of the format 23/05/2013 15:30:31 , with respectively date, and day time to the second.
My exaple dataset set looks as below:
time Currency counterparty type x-rate
23.05.2013 9:00:01 eur/usd bank 1.36
... 10:03:25 eur/usd corporate 1.35
... 11:05:10m eur/usd non bank financial 1.34
...12:30:45 eur/usd government 1.35
...13:35:10 eur/usd corporate 1.35
Question
I imported the dataset as an unstructed dataset. Could you tell me how to update it using the time variable and convert it into a dated-frequency dataset which takes into account the level of detail of the date/time variable?
Many thanks for your feedback.
Neo
eviews example dataset.xls
(72 KiB) Downloaded 445 times
Re: How to update a high frequency dataset using a timestamp
Postby EViews Gareth » Thu May 23, 2013 7:48 am
I think you'll need to provide the file.
neophytosk
Postby neophytosk » Fri May 24, 2013 5:02 am
I provided an example file. The date variable is 'last modification date'
Best
Neo
Postby EViews Gareth » Fri May 24, 2013 7:59 am
You have observations with the same value of last_modified_date. Therefore you cannot use it as a date series to structure the workfile by.
neophytosk
Postby neophytosk » Fri May 24, 2013 8:46 am
These are trades which occur at the same exact time......i.e two customers trade at the same time with the bank
What do you suggest as an alternative to structure the dataset? Is there a way to overcome this?
Let's first go with the easiest way, say i delete those trades which occur exactly at the same time(loss of informatíon will be limited), how do I then convert the dataset to dated structure?
Postby EViews Gareth » Fri May 24, 2013 8:54 am
Probably best off just leaving it as unstructured.
neophytosk
Postby neophytosk » Fri May 24, 2013 9:25 am
I need to structure the dataset - this post was created for this reason as I want to convert it from high to low frequency based on the time variable.
e.g sum up observations at 1 min or 10 minute intervals
Is this possible without structuring the dataset?
Postby EViews Gareth » Fri May 24, 2013 9:29 am
Yes, you can perform a general match merge, using your date/time variables as the IDs.
neophytosk
Postby neophytosk » Fri May 24, 2013 1:08 pm
this means that I have to make the assumption that each observation based on ID equals to some predefined time interval, e.g 1min right? from ID1 to ID5 the d(time)=4mins if we make the assumption that all observations are equally distributed in time?
let me know if this is the case and potentially share if possible a link on how to do the mergirg
how can I structure the dataset as discussed before? i will try the above merge proposal but i think i will not able to run my analysis in such a way.....
thnx
Postby EViews Gareth » Fri May 24, 2013 2:43 pm
No, you don't have to assume the observations are equally distributed. You just have to decide how you want to handle contractions of the observations with the same time.
neophytosk
Postby neophytosk » Sat May 25, 2013 3:57 am
Could you give me a code to execute this? I need test first your suggestion and see if this will give me the results I would like to get.
Postby EViews Gareth » Sun May 26, 2013 12:48 pm
Just copy from the first page, and then paste special into the second. User Guide I has quite detailed instructions on performing general match merge copying.
neophytosk
Postby neophytosk » Mon May 27, 2013 5:17 am
yup I 've tried that but I get the reply 'variables you are trying to merge are of the wrong type'
I have befoehand added a cell ID and date ID series and used those as 'source IDs'
test workfile frq conversion.wf1
(58.81 KiB) Downloaded 327 times
Postby EViews Gareth » Tue May 28, 2013 8:17 am
Post your workfile.
neophytosk
Postby neophytosk » Thu May 30, 2013 11:12 am
I attached an example workfile
I would like to convert from high to lower frequency using the date as ID. For example to sum up the group variables for a specific time frequency e.g 5min intervals. Rgd those trades which appear at the same time I propose to:
-use deal ID as an additional source variable since some deals are dublicated in the dataset
As mentioned before I tried the general merge approach and I get the error message:
“some of the specified series do not yet exist or are of the wrong type”
thanks for your support
(58.81 KiB) Downloaded 312 times
