I'm trying to estimate a particular Dynamic Factor Model in the following state-space system:
Signal Equation:
y(1,t)=a(1)*F(t)+u(1,t)
y(i,t)=a(i)*F(t)+u(i,t)
State Equations:
F(t)=b1*F(t-1)+b2*F(t-2)+E(t)-h*E(t-1)
u(1,t)=d(i)*u(1,t-1)+w(1,t)
u(i,t)=d(i)*u(i,t-1)+w(i,t)
That is quite close to a standard Dynamic Factor Model. However, the common factor (F) is allowed to follow an ARMA(2,1) process, rather than a usual AR(2) process, and residuals (u) follow an AR(1) process. This is the issue!
Suppose for a moment we got 3 variables (y1, y2, y3) and the common factor (F1) follows a standard AR(2) process, with innovation variance (V(eps)) set to 1 for ease of computation. Hence, the state-space representation should be:
sspace dfm
dfm.append @signal y1=c(1)*F1+e1
dfm.append @signal y2=c(2)*F1+e2
dfm.append @signal y3=c(3)*F1+e3
dfm.append @state F1=c(4)*F1(-1)+c(5)*F2(-1)+[ename=eps, var=1]
dfm.append @state F2=F1(-1)
dfm.append @state e1=c(6)*e1(-1)+[ename = e12, var=exp(c(9))]
dfm.append @state e2=c(7)*e2(-1)+[ename = e22, var=exp(c(10))]
dfm.append @state e3=c(8)*e3(-1)+[ename = e32, var=exp(c(11))]
dfm.append @evar cov(e12,e22) = c(12)
dfm.append @evar cov(e12,e32) = c(13)
dfm.append @evar cov(e22,e32) = c(14)
dfm.ml
dfm.makestates *_ss
After many trials, I could not find any useful representation for this problem.
Any clue?
Thank you very much.
