Rolling SUR Bug
sauleung
Rolling SUR Bug
Postby sauleung » Fri May 17, 2013 8:04 pm
Dear Eviews Managers,
I am an Eviews 8 user, on a windows 7 Fujitsu laptop.
I am running a rolling SUR with a loop structure.
When I run the programme, a window prompt came out and said eviews 8 has stopped working, and then eviews shut down.
Please can you advise what I can do with this error?
Thanks!
Attached is the programme.
SL
rolling sur.prg
(3.58 KiB) Downloaded 428 times
Re: Rolling SUR Bug
Postby EViews Gareth » Fri May 17, 2013 8:06 pm
What is the build date of your copy of EViews?
sauleung
Re: Rolling SUR Bug
Postby sauleung » Sat May 18, 2013 12:44 am
Hi Gareth,
Thanks for your reply.
May 17 2013 Build, I just updated the eviews after finding the bug, so it is updated to the latest version as of ytd.
Best regards,
SL
Re: Rolling SUR Bug
Postby EViews Gareth » Sat May 18, 2013 9:08 am
Could you provide the workfile on which you run the program?
sauleung
Re: Rolling SUR Bug
Postby sauleung » Sat May 18, 2013 11:03 am
Hi Gareth,
Attached is the workfile with port set up as a system containing the five portfolios (name start with R*).
Thanks a lot for your assistance! Much appreciated.
Best wishes,
SL
alpha.wf1
(20.22 KiB) Downloaded 436 times
Re: Rolling SUR Bug
Postby EViews Gareth » Mon May 20, 2013 7:47 am
Thanks, we'll get it fixed.
