Regression with Dummy Variables
Kiran Ujjawala Mehta
Postby Kiran Ujjawala Mehta » Fri May 08, 2009 2:38 am
I want to apply OLS with dummy variables. I have taken five days of the week and their daily returns for 5 years. while estimating the equation, i think i am not able to run the command in appropriate way. As i am using financial time series, plz help me out how should i run the command?
I simply tried it as
ser01 c ser02 ser03 ser04 ser05
is this the right way to use regression with dummy variables by using eviews software.
Re: Regression with Dummy Variables
Postby startz » Fri May 08, 2009 5:22 am
You need to use the ls command. You might find the first few chapters of EViews Illustrated, available online to be helpful.
trubador
Did you use forum search?
Postby trubador » Fri May 08, 2009 5:26 am
The way you are trying to do is only applicable when you are inside the equation dialog box. Carrying out the analysis from the command line is as follows:
equation eqname.ls ser01 c ser02 ser03 ser04 ser05
and if you also would like to see the output:
show eqname
