estimation
ivoryeview
estimation
Postby ivoryeview » Thu May 07, 2009 8:52 am
Hi, everyone.
I am doing GMM for a forward looking Talor rule model.
Here is the equation I input in the equation box
fed-(1-c(4))*(5.97-(c(2)-1)*c(1)+c(2)*inf+c(3)*gap)-c(4)*fed(-1)
Here is the IV list:
c gap(-1) gap (-2) gap (-3) gap(-4) fed(-1) fed(-2) fed(-3) fed(-4) spd(-1) spd(-2) spd(-3) spd(-4) cpi(-1) cpi(-2) cpi(-3) cpi(-4)
I keep facing the error message of nearly singular matrix
Re: GMM estimation with Singular error in IV
Postby EViews Gareth » Thu May 07, 2009 9:31 am
Estimation worked fine for me:
equation e1.gmm fed-(1-c(4))*(5.97-(c(2)-1)*c(1)+c(2)*inf+c(3)*gap)-c(4)*fed(-1) @ c gap(-1) gap (-2) gap (-3) gap(-4) fed(-1) fed(-2) fed(-3) fed(-4) spd(-1) spd(-2) spd(-3) spd(-4) cpi(-1) cpi(-2) cpi(-3) cpi(-4)
ivoryeview
Postby ivoryeview » Thu May 07, 2009 11:25 am
Thank you for reading my question and working on my work file.
I tried again, it still does not work
I use QUICK-->equation
Select GMM
Input the equations and IV
Select HAC Quadratic Newey-West
Iteration 1000
It tells me that "nearly singular matrix"
Could you try the results for these three workfiles for me?
Thank you
Postby EViews Gareth » Thu May 07, 2009 11:33 am
It won't work in EViews 5.1
It should work in EViews 6.0, as long as that copy of EViews 6 is up to date.
ivoryeview
Postby ivoryeview » Thu May 07, 2009 11:45 am
So it means that Eview 6.0 in the lab may not be updated such that GMM could be run?
But when I was taking the class I used to use Eview 6.0 in the lab to run another GMM estimation.
Is there any other way of solving this?
Postby EViews Gareth » Thu May 07, 2009 11:46 am
You could try removing one of your instruments.
ivoryeview
Postby ivoryeview » Thu May 07, 2009 11:56 am
I tried manipulating with the IV many ways , up to reducing them to 4
But everytime it reports nearly singular matrix.
Thank you
ivoryeview
Postby ivoryeview » Thu May 07, 2009 12:13 pm
I keep clicking on the OK button......it works after dozens of clicks....
OMG
Postby EViews Gareth » Thu May 07, 2009 1:42 pm
It is possible, since your equation is quite non-linear, that changing the starting values will alleviate the problem. Although GMM always uses 2SLS to obtain starting values, in non-linear cases EViews requires starting values for the 2SLS step.
Perhaps your starting values changed between your 11th click and your 12th.
pabalo
Postby pabalo » Sun May 10, 2009 8:24 pm
Firts of all, I apologise because I am new in this forum and I don't undestand exactly where to write. Anyway, I am sure that you are going to help me.
I am estimating a hybrid IS curve in GMM, using as instruments lags of the variables(dependent and independet). Well, the point is that if I use, for example, four lags of the variables (as instruments), I get some values for the coefficients, with the right signs for each variable. But, if I use, for example, six lags, I get again the right signs for the coefficients, but some of them change significantly. So, my questiong is how I can identify which set of instrument is the best for the estimation.
I know that I have to take into account the J-statistic provided by Eviews, but I don't know how I can compare the value of this test in the same spectification of the equation but with different set of instrument.
Thanks for your comment.
