Read in from Excel with source & units
seahorse
Postby seahorse » Tue Mar 26, 2013 11:31 am
Folks,
Very new to Eviews (this week). Appreciate your patience! I am trying to write a program that will read in a large list of series from Excel with all of their associated Meta Data (label, displayname etc.). Is this possible? I can only get in the data and the variable name. I don't want to have to manually type in all the sources, units etc. in Eviews.
Attached a very simple file with just two of the hundreds of variables I will need to import.
Appreciate the help
NG
bluebook.xlsx
example file
(12.32 KiB) Downloaded 432 times
Re: Read in from Excel with source & units
Postby EViews Gareth » Tue Mar 26, 2013 11:34 am
Which version of EViews are you using?
Postby EViews Gareth » Tue Mar 26, 2013 1:22 pm
In EViews 8:
wfopen bluebook.xlsx range="Readin!a1:c67" colhead=6 namepos=first rename variable_code_ year pageload(page=attrb) bluebook.xlsx range="readin!a1:c5" byrow colhead=1 namepos=first pageselect bluebook importattr(name="variable code:") attrb\
seahorse
Postby seahorse » Wed Apr 10, 2013 4:39 am
Gareth,
Thank-you so much. I have been off sick for a while and am just back today. This is so helpful to me I cannot tell you! I have been trying to understand how it works and I cant fully follow it but I am sure you are too busy to explain the code to me! However I have one follow up question, I want to read in the display name but it seems to come in as a separate text attribute with the same name (Display Name). I want the second label to be what it shows on charts so how do I get it to read that in from the spreadsheet? If I read in at present I get the following - two 'Display Name' attributes:
Display Name:
Last Update: Last updated: 04/10/13 - 12:26
Description: Expenditure, volume, private sector
Display Name: Expenditure, private sector
Source: Blue Book 2012
Units: £m
Remarks:
History: Imported from 'C:\EVIEWS_WORK\MODEL\bluebook.xlsx'
thanks in advance - this is so helpful for me. I am now Eviews version 8 (had a free upgrade as I bought Eviews 7 after Dec 12)
Neil
bluebook.xlsx
(12.31 KiB) Downloaded 413 times
seahorse
Postby seahorse » Wed Apr 10, 2013 5:18 am
Apologies Gareth,
I worked this out myself! I needed an underscore in the Display name in excel - too hasty asking questions!
Neil
