Problem with merged graph
renjinlu
Postby renjinlu » Thu May 07, 2009 9:15 am
Hi, I have a problem with merged graph and wonder if you could help me.
Suppose, say, I have 35 graphs all ends with the suffix "grp". I want to merge them into a singe birdview graph called forecast_overview. I used the following program line:
graph forecast_overview.merge {%grp}
Well, here comes the problem. Each individual graph in "forecast_overview" is so small, I can barely see them. It seems that Eviews insist on putting the merged graph, "forecast_overview" here, on a single screen. So, if there are too many small graphs merged into this big graph, I cannot see each graph clearly for each of them is so small.
Is there any command that I can use to exhibit part of the graph on the screen? Or, is there any other ways I can have a birdview of many graphes in a single graph but I can also control the display size of each mini graph in this big graph on my computer screen?
Thanks!
Re: Problem with merged graph
Postby EViews Glenn » Thu May 14, 2009 10:54 am
No. The closest thing to this is to put the graphs in a spool object...
