Repeated variable input
I have another relatively simply question.
I have a series called p85to89fz1p in which I want to manually input values for. There are 30 values I need to input, however the last 24 are all the same.
For example, this is what I am trying to do:
smpl 2006 2036
p85to89fz1p=5,6,6,6,8,9,10,10,10...........................10
The first 6 values are different, then the last 24 are all 10's. Is there a way I can avoid typing "10" 24 times?
I know in AREMOS the command was:
ser<2006 2036>p85to89f=5,6,6,8,9,10,10,10 repeat *;
Where the "repeat" function inputted 10's until the end of the specified time series.
Is there a similar command in EViews?
smpl 2006 2036
Re: Repeated variable input
One workaround is
smpl 2027 2036
p85to89fz1p = 10
smpl@allRe: Repeated variable input
This worked fine for the 10's part of it.
I can't seem to find out how to manually input different values for the series though, i.e. the p85to89fz1p=5,6,6,6,8,9 part for 2006 to 2011.
I have tried
smpl 2006 2011
p85to89fz1p= 5 6 6 8 9
smpl 2012 2036
p85to89fz1p=10 @all
however it tells me there is a syntax error in the p85to89fz1p= 5 6 6 8 9 part.
Are you able to provide advice about this?
I have tried
smpl 2006 2011
smpl 2012 2036
p85to89fz1p=10 @all
One way to do this is to open up the series to a spreadsheet view and type in the individual values.This worked fine for the 10's part of it.
I have tried
smpl 2006 2011
smpl 2012 2036
p85to89fz1p=10 @all
Yes, that is kind of a last resort for me though due to some other factors.
I'm sure there is a way to manually input variables into a series that is already made. I just can't seem to find how to do it
In EViews 8:
smpl 2006 2036
p85to80fz1p.adjust = 5 6 6 6 8 9 10 r24
Perfect!
Thanks a lot
Thanks a lot
Actually I may have spoken too soon.
I am getting an error message that reads:
ADJUST is not a valid view for P85TO89FZ1P in "DO_P85TO89FZ1P.ADJUST = 5 6 6 6 8 9 10 R24"
Any idea why this is happening?
Nope, Version 7.2
Sorry I didn't notice the 8.
So there is no way to do this in Version 7?
smpl 2006 2006
p85to80fz1p = 5
smpl 2007 2007
p85to80fz1p = 6
smpl 2008 2008
p85to80fz1p = 6
Ouch.
Gonna have to upgrade to Version 8 I guess haha
Thanks again man i appreciate all the help
