Panel VAR
samijo
Panel VAR
Postby samijo » Mon Oct 06, 2008 9:52 pm
Is it possible to estimate a Panel VAR in EViews? If for example I wanted to use the grunfeld standard data and run a VAR of the the three variables (I, K & M) allowing for fixed effects; is that possible?
Thanks,
Re: Panel VAR
Postby EViews Gareth » Mon Oct 06, 2008 10:38 pm
EViews doesn't have any panel VAR procedures built in.
Re: Panel VAR
Postby startz » Tue Oct 07, 2008 4:50 am
But since a VAR is just OLS, you may be able to get what you need by running panel LS and explicitly writing out the lags on the right hand side.
Gene
EViews Expert
Re: Panel VAR
Postby Gene » Tue Oct 07, 2008 11:21 am
Using OLS to estimate panel-VAR is one option. However, the literature suggests alternative ways for panel-VAR estimations. These alternatives are not, yet, available in EViews. It's not clear how much the OLS method deviate from the alternative methods.
devisetyo
Re: Panel VAR
Postby devisetyo » Thu Feb 21, 2013 4:03 am
i don't know how to write "the lags on the right hand side". could you please tell me how is my equation must be if I have variables U and E, and I want to try lag 1, 2, and 3.
E is Entrepreneurial activity, and U is unemployment. My paper is want to know the dynamic relationship between those two variables.
your answer will very helpful. If my question is not really clear, I'm ready to be asked :
Re: Panel VAR
Postby startz » Thu Feb 21, 2013 7:42 am
The lag of U is written U(-1), etc.
