programming GARCH(1,1) with an exogeneous variable
katyajas
Postby katyajas » Fri May 01, 2009 11:59 am
Hello again,
Could soemone please help on programming GARCH(1,1) and adding an exogeneous variable?
I do the following:
matrix(31,3) garchest_n
matrix(31,3)
for !i=01 to 31
equation eq{!i}.arch(1,1) tr{!i} c
garchest_n(!i,1)=c(3)
garchest_n(!i,2)=c(4)
garchest_n(!i,3)=c(5)
trubador
Did you use forum search?
Re: programming GARCH(1,1) with an exogeneous variable
Postby trubador » Fri May 01, 2009 12:41 pm
You can add exogenous variables into your mean equation just like the constant. For variance regressors you'll have to put "@" sign after the mean equation followed by your exogenous variables. For example: equation eq{!i}.arch(1,1) tr{!i} c xm @ xv
katyajas
Postby katyajas » Sat May 02, 2009 5:42 am
Many thanks for your help. It worked fine. :)
