Use Eviews 7.
I have a group consisting of daily returns of individual stocks. Need a sample that shows only daily returns of individual stocks above market return and make a new group with these observations. How can this be done? A spesific solution would be greatly appreciated.
sample in a group
Re: sample in a group
You'll have to be more explicit as to what you're trying to do.
martingale
Example
group members:
Company1 return 0,01
Company2 return 0,04
Company3 return 0,04
Market return 0,03
need to sample so that companies above market return form a new group, that is company2 and company3
group members:
Market return 0,03
Sorry, that still isn't clear.
You have a group. Roughly speaking, that's a matrix - each row is an observation, each column is a series. You want to set a sample (which selects observations, i.e. rows) so that the members of the group (i.e. columns) change. You can't do that.
martingale
just did it in Excel
'This part generates random data to simulate the current situation as I see it.
wfcreate u 100
group full
!market_ret = 0.01
for !i = 1 to 10
series y!i = nrnd
full.add y!i
'This is the actual part that is supposed to solve your problem (from my understanding of course).
group sample
for !i = 1 to full.@count
%s = full.@seriesname(!i)
if @mean({%s}) > !market_ret then
sample.add {%s}
endif
next-
martingale
Thank you! Some adjustment is needed.
I have individual files of daily returns for companies and the daily returns of the market as a whole for the same period of time.
The name structure for the individual companies is:
R_N_companyX_P_
where the component companyX varies from company to company.
The name for the market returns is:
r_msnwayl
The group name which includes all the above is:
R
I need EViews to:
Compare each company daily return with the market return and create a new group with the observations which are greater than the daily market returns for each day. I have 1445 daily observations and 207 companies.
The purpose of this is to run a test of the cross sectional absolute deviation(CSAD):
CSAD(t)=Sum(i=1,N){(1/N)absolutevalue(R(i,t)-R(m,t)}
where R(i,t) is the return of company I at day t and R(m,t) is the market return at day t, and N is the number of observations that fulfill the requirement Ri>Rm at a given day.
The prediction of rational expectations is that in the equation:
CSAD(t)=gamma(0)+gamma(1)absolutevalue(R(m,t)+gamma(2)(R(m,t))^2
gamma(1) is positive and gamma(2) is zero.
If gamma(2) is negative and significantly different from zero the interpretation is herding behavior in the market.
R_N_companyX_P_
r_msnwayl
R
I need EViews to:
martingale
a solution was found , you find the research done and the programming code used in e-views here: http://brage.bibsys.no/xmlui/bitstream/ ... ilidis.pdf
