subroutine grpset(string %grpnum, string %regnum)
'* Combines group components, creates test values and runs the grp_norm subroutine *
'* No calls *
'* String %vt is vt-refernce table name *
%gname="grp" + %grpnum + "_" + %regnum
' Calculate percent off of the sum of components to the parent component. Essentially this difference must be zero.
'Create an empty variable to hold the value of the sum of a group's elements
series sum=0
'Create a control variable for use in for loops
!g=1
'Start a for loop that goes through each element of %gname and adds the values of that element to the sum placeholder
for !g=1 to {%gname}.@count
'Add the current element of the FOR loop to the sum of all previous elements until the loop finishes running
sum= sum + {%gname}(!g)
'Creates a series called ptest{%grpnum} that creates a scale representing the difference between the parent group and the sum of all children groups
series ptest{%grpnum}_{%regnum} = (r{%regnum}_{%grpnum} - sum)/r{%regnum}_{%grpnum}
'Calls the subroutine "norm_group" for %gname, which then scales down the values of the children, based on the value of "ptest" so that when added together
'the children all equal the parent group
call norm_group(@str(%grpnum), @str(%regnum))
'Reset the "sum" placeholder to 0 so that
sum=0
'Essentially a repetition of the previous FOR loop, but this time using the scaled down values of the children elements
for !g = 1 to {%gname}.@count
sum=sum + {%gname}(!g)
'Create a series called "test{%grpnum}" that subtracts the sum of the children elements from the parent group. We expect to get a value of ZERO throughout the series
'"test" if the preceding steps went well
series test{%grpnum}_{%regnum} = (r{%regnum}_{%grpnum} - sum)
endsub
subroutine norm_group(string %grpnum, string %regnum)
'* Labels and sets conversion *
'* No calls *
%cname="ptest" + %grpnum+ "_" + %regnum
for !i=1 to {%gname}.@count
%sname={%gname}.@seriesname(!i) 'Variable name
{%sname}=@round({%sname}*(1+{%cname}))
endsub
for !i=0 to !i=6
' Set groups
group grp100_{!i} r{!i}_10 r{!i}_95 r{!i}_96 r{!i}_97
group grp10_{!i} r{!i}_101 r{!i}_102
group grp101_{!i} r{!i}_1011 r{!i}_1012 r{!i}_1013
group grp102_{!i} r{!i}_1021 r{!i}_1022 r{!i}_1023 r{!i}_1024 r{!i}_1025 r{!i}_1026 r{!i}_1027 r{!i}_1029
group grp1011_{!i} r{!i}_11 r{!i}_21
group grp1012_{!i} r{!i}_23
group grp1013_{!i} r{!i}_31_33
group grp1021_{!i} r{!i}_42 r{!i}_44_45 r{!i}_48_49 r{!i}_22
group grp1022_{!i} r{!i}_51
group grp1023_{!i} r{!i}_52 r{!i}_53
group grp1024_{!i} r{!i}_54 r{!i}_55 r{!i}_56
group grp1025_{!i} r{!i}_61 r{!i}_62
group grp1026_{!i} r{!i}_71 r{!i}_72
group grp1027_{!i} r{!i}_81
group grp1029_{!i} r{!i}_99
call grpset("10", @str(!i))
call grpset("100", @str(!i))
call grpset("101", @str(!i))
call grpset("102", @str(!i))
call grpset("1011", @str(!i))
call grpset("1012", @str(!i))
call grpset("1013", @str(!i))
Syntax error in "FOR !G=1 TO GRP100_3.@COUNT
This always seems to happen for whichever group is second in the list of "call grpset." I don't understand why this is happening, because I expect the program to try and deal with GRP100_0 before it reaches GRP100_3. Does it looks like something is adding numbers to the %regnum variable that I haven't noticed?
I appreciate any advice
