The required number of observations
how many observations will i need for the VAR regression with 14 regressors? apparently, 28 is not enough. attached is the workfile in case it's needed. thanks in advance
- new2.wf1
- (13.7 KiB) Downloaded 171 times
Re: The required number of observations
The minimum is the lag length times the number of variables, plus 1. As a practical matter, you need a fair number more than that.
ok, thanks a lot for the reply!The minimum is the lag length times the number of variables, plus 1. As a practical matter, you need a fair number more than that.
