smpl @all
_al_1.scenario(n, a=_ss1) "sc 2"
_al_1.scenario(c) "baseline"
_al_1.scenario "sc 2"
smpl 1995 @last
GENR QSsec_a = QSsec*0.1
smpl @all
_al_1.addassign(v) QSsec
smpl 1958 2010
_al_1.solve(s=d, d=d, a=f, f=f)
smpl 1958 2010
_al_1.makegraph(a, g=v, c) _m1_sc2_g @endog
_al_1.makegroup(d, g=v, c, t=pch) _m1_sc2_t @endogHow can I protect the baseline values so that the baseline is solved without using the add factor?
I see the following from p.539 in the Eviews User Guide II:
"If an add factor is present in any scenario, then it must be present in every scenario, although the values of the add factor can be overridden for a particular scenario in the same way as for an exogenous variable."
However, it's not possible to use an override on the baseline scenario, so I don't think this helps me much...
