I saw various subject on the forum dealing with how to include garch effect into the state space object. As it require to use a modified kalman filter to deal with the non-linearity, there is no solution directly in Eviews.
My objective is to estimate a CAPM and to get thanks to the kalman filter time varying coefficient. I would like to put a garch(1,1) effect on the error of my CAPM (like in GROUT and ZALEWSKA). To deal with this problem i have proceed recursively :
For me this procedure work fine, and beginning with the kalman filter or the garch don't seem to change nothing. However, I would like to know if this methods is not misleading. For me it's better than estimating the CAPM without garch effect, but i would like to have your advice.
I hope i've made myself clear (sorry for my english), here i put my eviews code, thank you very much for your help :
smpl @all
'Initial values estimation
smpl @first @first+91
equation eq_ftel_ini.ls rfc_ftel rfc_sbf c
sym(2) svar2=eq_ftel_ini.@coefcov
vector svec2=eq_ftel_ini.@coef
smpl @all
'Time varying beta estimation with constant volatility
sspace ftel_ss
ftel_ss.append @signal rfc_ftel = sv2 + sv1*rfc_sbf + [var = exp(c(1))]
ftel_ss.append @state sv1 = sv1(-1) + [var = exp(c(2))]
ftel_ss.append @state sv2 = sv2(-1) + [var = exp(c(3))]
ftel_ss.append @mprior svec2
ftel_ss.append @vprior svar2
ftel_ss.ml
ftel_ss.makestates(filt) ftel_beta ftel_alpha
'Volatility estimation with GARCH(1,1)
equation eq_garch1.arch rfc_ftel-ftel_beta*rfc_sbf-ftel_alpha
eq_garch1.makegarch ftel_garch1
'Beta estimation with previously estimated volatility
sspace ftel_ss1
ftel_ss1.append @signal rfc_ftel = sv2 + sv1*rfc_sbf + [var = ftel_garch1]
ftel_ss1.append @state sv1 = sv1(-1) + [var = exp(c(1))]
ftel_ss1.append @state sv2 = sv2(-1) + [var = exp(c(2))]
ftel_ss1.append @mprior svec2
ftel_ss1.append @vprior svar2
ftel_ss1.ml
ftel_ss1.makestates(filt) ftel_beta_1 ftel_alpha_1
'Iterative estimation between kalman and garch
for %num %pnum 2 1 3 2 4 3 5 4 6 5 7 6 8 7 9 8 10 9 11 10 12 11 13 12 14 13 15 14
equation eq_garch{%num}.arch rfc_ftel-ftel_beta_{%pnum}*rfc_sbf-ftel_alpha_{%pnum}
eq_garch{%num}.makegarch ftel_garch{%num}
sspace ftel_ss{%num}
ftel_ss{%num}.append @signal rfc_ftel = sv2 + sv1*rfc_sbf + [var =ftel_garch{%num}]
ftel_ss{%num}.append @state sv1 = sv1(-1) + [var = exp(c(1))]
ftel_ss{%num}.append @state sv2 = sv2(-1) + [var = exp(c(2)) ]
ftel_ss{%num}.append @mprior svec2
ftel_ss{%num}.append @vprior svar2
ftel_ss{%num}.ml
ftel_ss{%num}.makestates(filt) ftel_beta_{%num} ftel_alpha_{%num}
