Hello again!
Could you explaine, what does mean "t-statistic" criteria? for what should I set p-value for this criterion? I can't find info in Userguide.
Automatic selection for DF GLS test - 2
Re: Automatic selection for DF GLS test - 2
Test successively higher lag terms for statistical significance using a t-test with the specified p-value. Stop when there is a lag that is insignificant according to the test. It's a relatively new option that escaped documentation. It's a pretty standard approach that is discussed in all of the papers.
kiber_master
Sorry, but I didn't catch =(
Could you give a reference at least on one of the papers you mentioned?
And does this autoselection method correct sample using max lag, as other methods do?
Ng and Perron “Unit Root Tests in ARMA Models with
Data-Dependent Methods for the Selection of the Truncation Lag,” JASA, 1995.
