Postby Robotek » Tue Aug 07, 2012 5:14 pm
Aha, right. The C&D MVR seemed ridiculously strict to me (from RWH null perspective) as I had the idea that it is (quite) equally distributed as the L&M SVR test, when obviously the number of lags tested, as a property of SMM, remarkably ‘penalize’ the p-value of the joint max |z|.
Another thing your last reply might indicate, let me see if I understood it correctly.
The fact that I run the VR test for multiple lags, even though I’m in a way investigating individual lags separately and hence each one is a single test, would that itself make the test a C&D? And forth, all individual lag results are hence nonsense as only the joint part of the results matter? This is a bit hard for me to believe because i) articles I’ve read that take the L&M approach, as few as they are in comparison to the C&D ones, do investigate a set of lags (commonly 2,4,8,16) and ii) the ones taking the C&D approach seem to put equally much attention to interpreting VR’s of single lags as the joint test. Of course, the common argument is that the L&M is inadequate as VR should equal 1 for all q (i.e. not only at e.g. lag 2, 4, 8, 16) under the RWH. But still the test is used, often with the added conclusion “… however, too much weight shouldn’t be put to these results as VR should equal 1 at all q…”. Is it in this context you state “…you can't just use the lag with the largest t-statistic as the size of the test is not valid when…”, hence simply stating that L&M were wrong? If so, my question on critical values of z (in the asymptotic normal distribution) is motivated, and I’ll have to underline my low knowledge level in statistics by saying/asking: I like distribution tables, and I'm familiar with tables of the F-distribution, student’s t-distribution, chi-squared-distribution ... - do I use e.g. any of those when interpreting z-values from the L&M tests that are asymptotic normally distributed? I sure haven’t seen any ‘AND’ table lying around.
