Transformation of series - returns NAs
sean123
Postby sean123 » Thu Nov 15, 2012 8:45 am
I'm composing a program which makes a number of forecasts. At the beginning of the program, data is read from an Excel file. The data is in its original form, and further transformations are needed before the forecasts are made.
What I want is essentially that some of the series are transformed, but his, however, returns NAs as long as I perform it on the series themselves! For example, you may run the following program.
wfcreate q 1990q1 2009q4 genr y=nrnd series x=d(y) y=d(y)
y is full of NAs where x consists of the differentiated original y series, and this is what I want. My solution is basically this, but instead of a generated series I apply this to my data read from Excel:
wfcreate q 1990q1 2009q4 genr y=nrnd rename y y2 y=d(y2) d y2
This feels a bit clumsy and I would like to find a cleaner way around this. Anyone have any ideas?
Re: Transformation of series - returns NAs
Postby EViews Gareth » Thu Nov 15, 2012 9:08 am
EViews calculates series sequentially (and if it didn't, lots and lots of things would break). Thus what actually happens when you type:
y=d(y)
is that the very first observation for Y is calculated first. It is set to NA, since there is no value for lagged Y in this case, so the difference has to be an NA.
Then the second observation is calculated. We just updated the first observation to an NA, so now the second observation, calculated as the second observation minus the first, receives an NA. Then the third observation is calculated, also getting an NA, and so on...
There is no way around it, other than by doing what you're doing.
Of course, given that EViews will let you use the expression d(Y) in pretty much any calculation you'd want to make, there usually isn't really a need to create the transformed series in the first place.
sean123
Postby sean123 » Fri Nov 16, 2012 12:31 am
Thanks, Gareth. I was suspecting that the NAs were a result of the type of calculation you described. I'll use my way around it then, but at least now I know for sure that there is nothing else causing the missing observations.
