Loop ARMA model
Eva_87
Loop ARMA model
Postby Eva_87 » Thu Oct 18, 2012 10:40 am
Hey guys, I heard this is a great site for getting help. I need to loop an ARMA model, but I can only get a simple arma model like this one:
for !i= 1 to 6 for !j= 1 to 6 equation name_abc_!i_!j.ls dnameabc c ar(!i) ma(!j) next next
so the output is actually dnameabc c ar(1) ma(1) and dname_abc c ar(5) ma(4) for example but I need:
dname_abc c ar(1) ar(2) ar(3) ma(1) ma(2) ma(3) ma(4) for example and not a simple model equation.
Re: Loop ARMA model
Postby EViews Gareth » Thu Oct 18, 2012 10:53 am
Eva_87
Re: Loop ARMA model
Postby Eva_87 » Thu Oct 18, 2012 12:38 pm
Ohh that works :o ! amazing! Thank you soo much :D
Eva_87
Re: Loop ARMA model
Postby Eva_87 » Thu Oct 18, 2012 2:03 pm
One question though, now that it returns the best fitted model it says either that the process is nonstationary or it says that MA is noninvertible :S. So, where seems to be the problem?
Re: Loop ARMA model
Postby startz » Thu Oct 18, 2012 3:24 pm
You might want to post the offending output. The issue is likely to be econometric rather than software.
Eva_87
Re: Loop ARMA model
Postby Eva_87 » Fri Oct 19, 2012 2:41 am
Never mind. I used the return percentages as dependent in the formula instead of the normal returns. When I used the normal returns, it did its job ;) :D
