Output variable to file
Patrick
Postby Patrick » Wed Oct 10, 2012 1:52 am
Hi, I have a simple regression that I output to a text file via
... output(t) filename.txt equation eq.stepls() portfolio c @ somegroup eq.stats(p)
I also have a string variable %sometext that I would like to print to the text file somewhere. Anywhere is fine. How do I do this?
Re: Output variable to file
Postby EViews Gareth » Wed Oct 10, 2012 7:46 am
string temp = %sometext print temp
Patrick
Postby Patrick » Thu Oct 11, 2012 1:32 am
Thanks Gareth, i tried to do print %day but declaring a string was the solution.
What's the difference between these?
%test = "Hello" string test = "Hello"
Postby EViews Gareth » Thu Oct 11, 2012 6:18 am
One makes a program variable, that exists only whilst the program is running, the other makes a workfile object.
