double Log Linear
double Log Linear
I found error that " near singular metrix",what does it mean? what should I do the next? How to deal with this problem?
Re: double Log Linear
It means that a matrix that you're trying to invert is close to, or is, singular.
Without knowing what you're doing, its hard to say what you should do next.
I'm trying to estimate regression after take log dependent variable and independent variable. There're 2 dummy in this equation.
" lnmd c lnpm lnpy lnyd d1 d2" after I put in this command that error was shown.
Most likely d1+d2=1. This is the dummy variable trap. It means the equation is misspecified.I'm trying to estimate regression after take log dependent variable and independent variable. There're 2 dummy in this equation.
