How to determine if an estimated GARCHmodel is wellspecified
T27667
Postby T27667 » Sat Sep 29, 2012 9:57 am
How do I determine if my estimated GARCH(1,1) model is well specified?
Output:
Dependent variable : 100timesLogReturn
Mean Equation : ARMA (0, 0) model.
No regressor in the conditional mean
Variance Equation : GARCH (1, 1) model.
No regressor in the conditional variance
Normal distribution.
Strong convergence using numerical derivatives
Log-likelihood = -2008.98
Please wait : Computing the Std Errors ...
Robust Standard Errors (Sandwich formula)
Coefficient Std.Error t-value t-prob
Cst(V) 0.010869 0.0047526 2.287 0.0223
ARCH(Alpha1) 0.107741 0.019644 5.485 0.0000
GARCH(Beta1) 0.886280 0.019819 44.72 0.0000
No. Observations : 1516 No. Parameters : 3
Mean (Y) : 0.00664 Variance (Y) : 1.60670
Skewness (Y) : -0.07797 Kurtosis (Y) : 14.15044
Log Likelihood : -2008.982 Alpha[1]+Beta[1]: 0.99402
The sample mean of squared residuals was used to start recursion.
The positivity constraint for the GARCH (1,1) is observed.
This constraint is alpha[L]/[1 - beta(L)] >= 0.
The unconditional variance is 1.81809
The conditions are alpha[0] > 0, alpha[L] + beta[L] < 1 and alpha + beta >= 0.
=> See Doornik & Ooms (2001) for more details.
The condition for existence of the fourth moment of the GARCH is not observed.
The constraint equals 1.0113 and should be < 1.
=> See Ling & McAleer (2001) for details.
TESTS :
Series #1/1: Standardized Residuals
Normality Test
Statistic t-Test P-Value
Skewness -0.34030 5.4145 6.1445e-008
Excess Kurtosis 0.83624 6.6571 2.7920e-011
Jarque-Bera 73.431 .NaN 1.1339e-016
ARCH 1-2 test: F(2,1511) = 0.83706 [0.4332]
ARCH 1-5 test: F(5,1505) = 1.5701 [0.1654]
ARCH 1-10 test: F(10,1495)= 0.89224 [0.5397]
If I have understood correctly Alpha[1]+Beta[1] = 0.99402 (=~ 1) indicates that the model is misspecified, right?
On the other hand, there is no ARCH effects in the residuals as requested.
However, these residuals are not normal as assumed.
All this put together, can anybody tell me if the GARCH(1,1) model is well specified?
The data is attached btw.
FTSE-100.xlsx
(124.45 KiB) Downloaded 422 times
ophadnavis
Re: How to determine if an estimated GARCHmodel is wellspeci
Postby ophadnavis » Wed Oct 03, 2012 5:32 am
Why are you taking 100 times logreturn as dependent variable. Can we not taken only logreturn for computation?
Regards
ophadnavis
Output:
TESTS :
Normality Test
T27667
Postby T27667 » Wed Oct 03, 2012 8:24 am
I just multiplied by 100 in order to avoid small numbers in the series, but you can do both
ophadnavis
Postby ophadnavis » Wed Jan 22, 2014 3:39 am
How do you specify positive constraint for alpha and beta in eviews?
