using stochastic simulation '' Urgent Situation''
Husseinfr1
PLEASE an Urgent Situation
Hi, all thank you in advance for help
I am new EViews user (7.2), currently I am working to solve macroeconometric model, which consists of 38 endogenous equations, 16 of which are stochastic while the rest are identities. I want to solve the whole model to test its predictive ability, using stochastic simulation, and I need to use the conventional criteria such as (MAE, RMSE, MAPE, the Theil inequality coefficient), but I could do that, because I do not find how. In the single equation, I can do from the equation widow, where the forecast option is available in that window.
Could you please help me, I am in an urgent situation.
Thank you again
Hussein
Thank you again
Hussein
Re: using stochastic simulation '' Urgent Situation''
There is nothing built in that will show you those values automatically. However there are functions that can calculate them for two series. For example you can type:
to show the RMSE between the series Y and the series Y_1.
=@rmse(y, y_1)
Husseinfr1
Thank you very much, but what about the rest cretira (MAE , MAPE, the Theil inequality coefficient)There is nothing built in that will show you those values automatically. However there are functions that can calculate them for two series. For example you can type:to show the RMSE between the series Y and the series Y_1.Code: Select all
=@rmse(y, y_1)
I am very happy and thank you very much for the quick reply.
@mae, @mape, @theil
Husseinfr1
Dear Gareth@mae, @mape, @theil
Thank you again, you provided me a great favor.
Best regards
Husseinfr1
I am so sorry,@mae, @mape, @theil
but it does not work
Could you please write the full command for me, my data series 1970 2006
the variables are pcer and pcer_0
thank you
=@mae(pcer, pcer_0)
Husseinfr1
I apologize, it seems that I disturbed you, but I wrote this command at the command windowCode: Select all
=@mae(pcer, pcer_0)
mapcer=@mae(pcer, pcer_0)
Is it true, if it is incorrect, what is the correct?
Where can I find the result?
if you wish to store the result in a scalar, called mapcer, then:
scalar mapcer = @mae(pcer, pcer_0)
Husseinfr1
Thank you so much Garethif you wish to store the result in a scalar, called mapcer, then:Code: Select all
best regards
Hussein
Husseinfr1
Hi GarethThere is nothing built in that will show you those values automatically. However there are functions that can calculate them for two series. For example you can type:to show the RMSE between the series Y and the series Y_1.Code: Select all
=@rmse(y, y_1)
Could you please show me how can I calculate the root mean squared percent error rmspe.
thank you inadvance
Hussein
There is nothing built in to calculate that statistic. You'll have to calculate it manually.
Husseinfr1
Thank you very much Gaerth for your help.There is nothing built in to calculate that statistic. You'll have to calculate it manually.
With best regards
Hussein
