Removing duplicates in panel data
I have a work file with a undated panel (see attached example). Unfortunately it contains quite a few duplicates. How would I remove the superfluous entries?
- example.wf1
- (8.98 KiB) Downloaded 315 times
Re: Removing duplicates in panel data
How are you defining a duplicate?
Two observations with identical values for all variables.
Can't think of an easy way to do it. This might get you most of the way there:
Make sure you have a backup before trying it though!
pagecontract if country<>country(-1) or flow<>flow(-1) or value<>value(-1) or year<>year(-1) or @trend=0
If preceded by
your code should settle it, don't you think?
sort country flow value year-
probably.
