Specify exogenous variables in "coint" command
rdwest
Postby rdwest » Wed Feb 24, 2010 10:53 am
I am using the Johansen test for cointegration. When performing the test on a single group of series using the drop-down menu, it is to specify exogenous explanatory variables. However, I don't see any options in the Command Reference (under the command "coint") to list exogenous variables. Does anyone know how to do this?
For example, in the following expression, how would I include an exogenous variable x3?
coint(c,1) y x1 x2
Thank you,
Rachel
Re: Specify exogenous variables in "coint" command
Postby EViews Gareth » Wed Feb 24, 2010 11:01 am
You can specify them with an @ sign after the coint command:
coint(c,1) y x1 x2 @ x3
alunde
Postby alunde » Sun Aug 26, 2012 1:40 pm
But how does this work for the engle-granger test
Writing
coint(method=eg) y x1 x2 @ x3
does not include x3 in the exogenous list.
Please help?
Postby EViews Gareth » Sun Aug 26, 2012 1:52 pm
As per the Command Reference:
coint(method=eg) ser1 ser2 [...ser3 ser4 ...] [@determ determ_spec] [@regdeterm regdeterm_spec]
