testing suspected endogenous variables
btwhow
Postby btwhow » Wed Aug 08, 2012 5:34 pm
what is the best way to test suspected endogenous variables in eviews - so far I have run tests via gmm and 2sls
thanks
m
Re: testing suspected endogenous variables
Postby startz » Wed Aug 08, 2012 5:36 pm
Run TSLS then choose View/IV Diagnostics/Regressor Endogeneity test
btwhow
Postby btwhow » Wed Aug 08, 2012 5:45 pm
Thanks - its sounds like i am on the right track
the result for the three variables that i tested show as:
"Endogenous variables to treat as exogenous: var1 var2 var3"
does that mean that the three variables that i tested are not endogenous?
m
Postby startz » Wed Aug 08, 2012 6:20 pm
No, that means that's those are the variables being tested.
btwhow
Postby btwhow » Wed Aug 08, 2012 6:51 pm
Thanks,
i had interpreted that part of the output from the test that I should treat the suspected endogenous variables as exogenous - meaning that they were exogenous and not endogenous.
how do I interpret the results then?
does the answer lie in the remainder of the output from the endogenous test of these variables - ie. the difference in value, degrees of freedom and/or probability, the j-statistic summary, the restricted test equation, or the unrestricted test equation?
m
Postby startz » Wed Aug 08, 2012 7:28 pm
You want to look at the difference in J-stat
btwhow
Postby btwhow » Wed Aug 08, 2012 8:16 pm
Thanks,
m
