GetStocks (fetch stock data)
Re: GetStocks (fetch stock data)
Postby startz » Wed May 18, 2011 2:47 pm
Note that the GetStocks add-in uses "D" for a keyboard shortcut, which seems to be masked by the keyboard shortcut for Download add-ins.
utah777
Postby utah777 » Tue Aug 07, 2012 2:54 am
Is it possible to download daily stock data into dated workfile?
Weekly and monthly data are OK, but dailies are totally messed up: when the data are downloaded into undated workfiles most recent quotes appear at the top of the data sheet and consequently moving averages are calculated forward looking. E.g. Techincal Analysis add-in, techasis, Bollinger Bands (20 periods,2 standard deviation):
obs AAPL_DATE AAPL_CLOSE OUT_HIGH OUT_LOW
1 2012-08-06 622.55 NA NA
2 2012-08-06 622.55 NA NA
3 2012-08-03 615.70 NA NA
4 2012-08-02 607.79 NA NA
5 2012-08-01 606.81 NA NA
6 2012-07-31 610.76 NA NA
7 2012-07-30 595.03 NA NA
8 2012-07-27 585.16 NA NA
9 2012-07-26 574.88 NA NA
10 2012-07-25 574.97 NA NA
11 2012-07-24 600.92 NA NA
12 2012-07-23 603.83 NA NA
13 2012-07-20 604.30 NA NA
14 2012-07-19 614.32 NA NA
15 2012-07-18 606.26 NA NA
16 2012-07-17 606.94 NA NA
17 2012-07-16 606.91 NA NA
18 2012-07-13 604.97 NA NA
19 2012-07-12 598.90 NA NA
20 2012-07-11 604.43 577.5353 629.2627
21 2012-07-10 608.21 578.3012 627.0628
There is no such issue with weeklies and monthlies.
Postby EViews Gareth » Tue Aug 07, 2012 9:20 am
I don't follow. If I run the add-in and grab IHS daily data, it puts it into an irregular daily dated workfile.
utah777
Postby utah777 » Tue Aug 07, 2012 1:20 pm
Well, now after trying again, it works properly.
I have no idea what have changed, but you may see yourself from my earlier example that the workfile was undated and consequently TA moving averages were from the future.
Let's see if this issue might occur one more time
Eviewsbeginner
Postby Eviewsbeginner » Fri Oct 26, 2012 7:48 pm
I am using Eviews 7, but I cannot open AIPZ fille. How can I open it? Thanks so much.
Postby EViews Gareth » Fri Oct 26, 2012 10:57 pm
Are you using EViews 7.2?
hhhcj
Postby hhhcj » Wed Mar 20, 2013 11:17 pm
why i cann't fetch stock data use GCH13.CMX to fecth future data and use GDO.NX to fecth currency data. The addin is very good ,but can you solve my problem?
Postby EViews Gareth » Thu Mar 21, 2013 7:53 am
Looks like Yahoo Finance doesn't provide those stocks in the same format.
Return to “Add-in Support”
