@wfindnc help
jbourque
Contact:
@wfindnc help
Postby jbourque » Thu Jul 26, 2012 1:42 pm
I'm d
owloading a large number of data series from Haver in E-views, some of which are in million, some are in billions. This is indicated in the series description (for example: "Anguilla: Stock of Domestic Credit (Mil.XCD)". In my program, I need everything to be in billions to calculate a ratio.
I was trying to find a way to seach the description string and return a positive number if it contains "Mil" or "mil", 0 if it does not. I tried a combination of the @wfindnc and @description commands to do that, but it doesn't seem to be working (I always get 0, even on series I know are in millions).
%temp = seriesname.@description
!million = @wfindnc(%temp,"mil")
Any help on how to make this work?
Thanks,
Jerome
EViews Esther
Re: @wfindnc help
Postby EViews Esther » Thu Jul 26, 2012 2:50 pm
%temp = seriesname.@description !million = @wfindnc(%temp,"mil")>0 'will return 1 if the string contains "mil", 0 otherwise.
jbourque
Contact:
Re: @wfindnc help
Postby jbourque » Fri Jul 27, 2012 6:17 am
Thanks, but it doesn't appear to be working on the series I'm applying them too. The code always returns 0 no matter the value I put in between quotation marks ("mil", "Mil", "MIL").
I'm attaching the workfile containing a sample of the series I have, and the list of series where the description says the magnitude is in millions. Any help is greatly appreciated.
Thanks again.
Jérôme
sodc.txt
list of series in millions
(590 Bytes) Downloaded 426 times
sodc.wf1
Sample of series downloaded from Haver. Description shows that series are either in Mil or Bil of the country's currency
(49.11 KiB) Downloaded 341 times
EViews Esther
Re: @wfindnc help
Postby EViews Esther » Fri Jul 27, 2012 8:19 am
The problem is that the term "Bil" cannot be separable from the string "(EOP, Bil.Pounds)". For instance, when you do
!million = @wfindnc(a112sodc,"(EOP, Bill.Pounds)")>0
you will get !million=1.
Why don't you try this one instead?
%temp = seriesname.@description !million=@instr(%temp,"Mil")
