the estimateors between Pooled and random effect
hongchontim
Postby hongchontim » Thu Jul 26, 2012 2:40 pm
Dear all,
I tried to use the pool and panel regression for analyzing the data.
Finally, I found that the coefficients from the pool and random effect models are identical except the t-test statistic has the a bit different.
Does anyone has this problem before?
Can anyone give me some advice?
Cheers,
Tim
hongchontim
Re: the estimateors between Pooled and random effect
Postby hongchontim » Thu Jul 26, 2012 2:42 pm
One should notice that I add the lagged dependent variable into the both models and it has the higher coefficients.
Postby EViews Glenn » Thu Jul 26, 2012 4:04 pm
Can you send post the workfile and information on the specifications, or send them to support@eviews.com along with your serial number and build-date.
