Johansen cointegration test
Hi, if my series do not have unit root (stationary), can i do Johansen cointegration test?
Re: Johansen cointegration test
Cointegration tests checks the long run relationship between variables. If your variables are stationary, then you do not need to apply cointegration test (in this case Johansen)
Some papers run Johansen cointegration even if the variables have been found to be I(0). If two variables are I(0) is it wrong to run a cointegration test?
The purpose of testing for cointegration is to see if a group of non-stationary variables share a relationship that is stationary. So there I don't see a reason to do this for stationary variables. Straight OLS can give you residuals that are not serially correlated.
