Estimating two linear equations (one after the other)
stephanie22
Postby stephanie22 » Mon May 21, 2012 11:41 am
Hi guys,
I am trying to estimate a model containing two linear equations.
(1) R = a0 + a1Vt-1 + a2ABt-1
I want to use the estimated R from equation 1 and use it as an independent variable in the second equation:
(2) Q = a0 + a1(R) +.....
I can obviously estimate equation 1 with standard OLS, however, I have no idea how to save these estimated R values in eviews
in order to use it in the second equation.
Also, I was wondering if there is an eviews function where you can view a graph of the estimated equation, I can only find a graph
of the residuals of the equation.
Thank you very much in advance!
Re: Estimating two linear equations (one after the other)
Postby EViews Gareth » Mon May 21, 2012 12:11 pm
You want the fitted values from Equation 1, which can be obtained by hitting the forecast button (fitted values are just a static forecast over the original estimation sample, after all).
What does a "graph of the estimated equation" mean?
stephanie22
Postby stephanie22 » Mon May 21, 2012 12:35 pm
Thank you very much!
Forget what I said about the graph, cause I get it now :D
I have one more question.
I also estimate a 'rental adjustment equation'.
First I estimate R* = a0 + a1Vt-1 + a2ABt-1
Following, I want to estimate the adjustment process, which is:
Rt-Rt-1 = a3 [R* - Rt-1]
If you fill R* in the above equation, I get:
(1) Rt = a3[a0 + a1Vt-1 + a2ABt-1] + (1-a3)Rt-1 (where a3 gives the rate of adjustment)
How can I estimate equation 1 in eviews? What should I type in the estimate equation box?
Thanks in advance!
Postby EViews Gareth » Mon May 21, 2012 1:09 pm
Something like:
R = c(4)*(c(1) + c(2)*v(-1) + c(3)*ab(-1)) + (1-c(4))*r(-1)
stephanie22
Postby stephanie22 » Tue May 22, 2012 12:53 am
thank you so much!
I have one last question:
If you assume a time trend in eviews, you can estimate '@trend'
If I include this variable in the regression, the signs of my coefficients change.
This change is good for my model, however are these signs reliable if I include a trend, because
without the trend the variables have the wrong sign.
