ADF test
cyp74
ADF test
Postby cyp74 » Mon May 07, 2012 9:17 pm
Hi, when I run the following line of code with any series, I still get the default setting "sic" for the information criteria. Any ideas? Thanks
seriesname.uroot(adf,trend,info=aic)
Re: ADF test
Postby EViews Gareth » Tue May 08, 2012 6:25 am
If you run that line in a program, you'll see that it does, in fact, use the AIC.
cyp74
Re: ADF test
Postby cyp74 » Tue May 08, 2012 2:26 pm
Thanks Gareth, you are right. I was testing it on the command line.
Re: ADF test
Postby EViews Gareth » Tue May 08, 2012 2:44 pm
A minority of commands don't behave the same way in the command line and in a program. Can be confusing/frustrating.
Re: ADF test
Postby EViews Glenn » Wed May 09, 2012 11:48 am
We'll make a note of this one and see how hard it is to get the dialog to read the command options.
