clearerrs/setmaxerrs
mike_d
Postby mike_d » Mon May 07, 2012 12:57 pm
I have a code I wrote and successfully used a few weeks ago that estimates VAR/VEC for 246 datasets depending on whether the variables are cointegrated or not. I use setmaxerrs and clearerrs in multiple parts of the code to deal with errors I know can occur. Like I said everything worked fine a few weeks ago, now I am trying to rerun everything to finalize the results however I am getting errors saying that 'setmaxerrs (clearerrs) is not defined or an illegal command.' I will post a snippet of code, any suggestions would be greatly appreciated.
''****************************************** '''johansen cointegration test ************************************************
''coint
setmaxerrs 50
!old_count = @errorcount
!new_count = 0
scalar counter = 0
group g1 s3
for !j = 9 to 14 step 2
g1.add s!j
freeze(coint_test!j) g1.coint(s,4)
!new_count = @errorcount
if !new_count > !old_count then
freeze(coint_test!j) g1.coint(s,2)
endif
freeze(coint_test!j) g1.coint(s,1)
endif
table(16,8) coint_test!j
endif
g1.drop s!j
next !j
clearerrs
Re: clearerrs/setmaxerrs
Postby EViews Gareth » Mon May 07, 2012 1:05 pm
I ran that code (on a test workfile) and it appeared to work ok. Are you using the same version of EViews?
mike_d
Postby mike_d » Mon May 07, 2012 1:08 pm
I am using eviews 7, the same version as before. I use it through an online server (citrix), they make updates occasionally but I am not sure if this would cause the problem.
Mike
Postby EViews Gareth » Mon May 07, 2012 1:13 pm
The interesting thing is that the error message seems to indicate that there is a line somewhere that says:
which doesn't exist anywhere in your code. Perhaps you commented out a large part of the code by mistake?
mike_d
Postby mike_d » Mon May 07, 2012 1:16 pm
I do not think I have changed anything since I last ran the code. I can set maxerrors manually after clicking run which allows it to loop through a couple files, I get errors on each line using those two statements.
Postby EViews Gareth » Mon May 07, 2012 1:20 pm
Perhaps you could post the .prg file and the corresponding workfile.
mike_d
Postby mike_d » Mon May 07, 2012 1:27 pm
I can post the .prg file, however I create a new workfile from datasets given in excel format each time. I have 246 excel files about 300kb each, altogether 68mbs. Is there a way to upload a folder of that size?
test_all_exogs_fixed.prg
(27.77 KiB) Downloaded 639 times
