Dear All,
I'm running some time series data, and planning to do classic OLS. but the problem is my variable time series data are not normally distributed. can you advice me what to do with it?
these are some histogram detail about my variables
Series: AVG_VAR
Sample 1 156
Observations 156
Mean 0.000662
Median 0.000412
Maximum 0.006918
Minimum 7.97e-05
Std. Dev. 0.000844
Skewness 4.201737
Kurtosis 25.60200
Jarque-Bera 3779.547
Probability 0.000000
Series: R_IHSG
Sample 1 156
Observations 156
Mean 0.001410
Median 0.001933
Maximum 0.070136
Minimum -0.109540
Std. Dev. 0.017897
Skewness -1.275486
Kurtosis 12.79372
Jarque-Bera 665.7592
Thanks in advance,
Ilham
Non-normal data
Re: Non-normal data
Run OLS.
Normality of the variables is completely irrelevant.
Re: Non-normal data
i need all variable in OLS to be normal distributed right?
Non-normal data
No.
Re: Non-normal data
Normality of the dependent matters in finite samples. The explanatory variables don't matter as long as they have finite second moments.
Re: Non-normal data
i thought the classic OLS assumption all variable involve is normally distributed?
Non-normal data
Nope, with the quintessential example being dummy variables, which are far from normally distributed, yet still perfectly valid.
Non-normal data
All that matters is that the error terms are normal. And that doesn't matter much. (As a minor quibble, the dependent variable need not be unconditionally normal. )
Re: Non-normal data
im running 2 variable right now
dependent is excess return and independent is average correlation
these 2 variable is stationer but and i regress it using OLS (newey-west). the result indicating the residual is not normal, so the estimation output consider to be biased dont it? how can i solve this problem?
Non-normal data
No, this does not cause bias.
