GARCH Model Depending Only On Logged Implied Vol
DJM
Postby DJM » Tue Apr 24, 2012 11:45 am
Hi Guys!
I am estimating a GARCH(1,1) model and it has an additional variance regressor. I want to obtain the likelihood ratio value when there are no ARCH or GARCH terms - so I only have the implied volatility appearing in the variance regressor.
However, when I set ARCH and GARCH to zero I get "must include one ARCH or GARCH term in specification."
I am using Eviews 7 and was hoping for some guidance, just a hint in the right direction. I had a quick search and couldn't find any responses to such a query. Any help would be greatly appreciated.
Best,
DJM
DJM
Re: GARCH Model Depending Only On Logged Implied Vol
Postby DJM » Tue Apr 24, 2012 2:08 pm
I am extremely new to this programme so if I am making an obvious mistake please let me know. Is what I have mentioned above even possible?
Thanks,
DJM
trubador
Did you use forum search?
Postby trubador » Wed Apr 25, 2012 2:15 am
You should write your own GARCH estimation procedure via LogL object, since the dialog box will not let you skip (G)ARCH specifications. There are several examples in the Sample Programs folder in EViews.
DJM
Postby DJM » Wed Apr 25, 2012 7:11 am
Thank you very much. I will proceed as advised.
Best,
DJM
